233 Intershield Wire
发表于 2021-8-31 23:49:04 | 显示全部楼层 |阅读模式
I'm about to do a 3&4G test on a 1" plates and need to know what to do and what not to do.I've run this wire very little and know that I should know more about it before testing on it.Any advice and help would be greatly appreciated.Thanks and be careful tomorrow.
Reply:Try using the serch feature Lots of info.   If you have never ran this wire before your in for a bad day.  GOOD LUCK, your going to need it.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Do some digging on here as there is some great advice that's been posted before. This is a common test for us and the advice on here aswell as LOTS of hood time helped me when I was testing. One tip I was can give you is learn to read the slag it'll gove you a hint as to what your leaving behind.
GMT+8, 2025-12-24 20:33 , Processed in 0.069896 second(s), 18 queries .
