Aluminum storage container
发表于 2021-8-31 23:48:57 | 显示全部楼层 |阅读模式
Hi all - I built from customer's plans a storage container, which is thankfully now completed and delivered.Specs:10" diameter x 27" tall cylindrical container, with an easily removable, gasketed lidwelded handle constructed from miter-cut tubing (6061, .065" thick, 5/8" OD)5052 aluminum main barrel (.065" thick) and end plates (.080" thick)TIG welded with a rock-solid reliable, 3 year old Everlast Super200P and 3/64" 5356 filler rodThe completed barrel is so strong, with it laid down sideways on the floor, I could stand on the open end without it deforming at all.  (The lid would still make a perfect fit afterwards.)  That said, the thick, strong barrel was a *real PITA* to form into a cylinder!
Reply:Nice work.  Very impressive!(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Thanks, strube!
Reply:Originally Posted by strube1369Nice work.  Very impressive!
GMT+8, 2025-12-24 20:22 , Processed in 0.092974 second(s), 18 queries .
