Torch won't stop popping
发表于 2021-8-31 23:48:53 | 显示全部楼层 |阅读模式
Today I got new tanks for my O/A, and while I was at the supply house, I picked up a new torch, and a tip.  But now it pops consistently.  Do I have an air leak?  Moisture in the lines?  Dirty?  Defective tanks?  What gives???
Reply:JC's Welding:See the Thread  "cutting torch popping constantly"  There is probably a way to link you to the discussion, but I do not know how to do it.  But you can search the forum for the title.  It should answer all your questions.Hope this helps!OAdoctorwww.regulatortorchrepair.com
Reply:Thanks, I should have used the search button first.  Sorry!
Reply:Originally Posted by OAdoctorJC's Welding:See the Thread  "cutting torch popping constantly"  There is probably a way to link you to the discussion, but I do not know how to do it.  But you can search the forum for the title.  It should answer all your questions.Hope this helps!
GMT+8, 2025-12-24 22:11 , Processed in 0.095412 second(s), 18 queries .
