Need to repair crack in brass
发表于 2021-8-31 23:48:47 | 显示全部楼层 |阅读模式
I have a brass part on my pool filter (not sure but I think it's cast) that has a crack on it and I would like to know if I can mig or tig it and if so what gas and filler.  I have some stargon, C25 and pure Argon gas.   I need a strong fix.  I don't have acetalyne but have some MAPP gas from Home D that I guess I could braze.  What would be the strongest fix.Thanks,
Reply:I would clean it prep it and use SILVALOY and Argon to TIG it. The SILVALOY seems to work with copper and Brass with MAPP. Ive been playing with SILVALOY , Helium and TIG on steel. Works for me. But Im a renegade weldor so lets see what an xpert suggests.
Reply:What kinda medicines???
Reply:clean it up and tig it with silbronzeMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:what ever method you choose, I would also bridge the repair with a re-enforcing piece a couple of inches long and tig/silver solder that too.Looks like it has cracked at a fairly weak point.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:My 1st thought is it looks exactly like a split when something freezes. That or the threaded piece bottomed out and applied too much pressure to the end.  If so, you'll probably have the same issue again unless you solve the underlying problem..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:the piece is over 40 years old and I think the inside rubber gasket was leaking and I probably over extruded  the screw too far which put excessive  pressure on the part when I pushed down on it to close it and it cracked.  Definitely my fault and not caused by freezing.
Reply:After seeing the last pic I'm with Gordon on this one add a fish plate over the crack to strengthen the area."Liberalism is a mental disorder" Dr. Savage
GMT+8, 2025-12-24 20:33 , Processed in 0.095508 second(s), 18 queries .
