Help finding steel split rings
发表于 2021-8-31 23:48:45 | 显示全部楼层 |阅读模式
Hey guys, I don't post to often but spend countless hours browsing the forum here drooling over much of the talent here..I wonder if any of you guys could help me located some steel split rings that you can use for bolting to tube like the one pictured below? Sizes im trying to find are 7/8' to 1-1/2 or so.  Thanks in Advance!
Reply:Junkster  -  Look for http: / / www. ReidSupply.com  -  Opus
Reply:You can also try-McMaster-CarrMSCFastenalGraingerSearch "split shaft collar"
Reply:Thanks Opus and Rancher, I guess I was looking for the specific name of that ring to help narrow my search.
Reply:Originally Posted by JunksterThanks Opus and Rancher, I guess I was looking for the specific name of that ring to help narrow my search.
Reply:If a shaft collar has a groove on one face or near one side on the O.D., it means that it is the face that is most perpendicular to the bore.  ... Perpendicularity is important for alignment when shaft collars are used as a bearing face, a mechanical stop, or for mounting other components. ...... the face that should be placed against a bearing or other component requiring a perpendicular to bore orientation. For Two-Piece collars, the face groove also helps keep the two halves of the Two-Piece collar properly oriented...."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:surplus center sells themhttps://www.surpluscenter.com/sort.a...split%20collarTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:http://www.mcmaster.com/#shaft-collars/=i6s52l...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-24 20:22 , Processed in 0.089384 second(s), 18 queries .
