90lb propane cylinder mount
发表于 2021-8-31 23:48:35 | 显示全部楼层 |阅读模式
Has anyone made mounting brackets for a 90lb propane cylinder? I have a customer that wants to mount 2 cylinders vertically to a forward trailer wall. I plan on cutting a dual saddle pattern out of 4x4 angle but cannot decide on the hold strapping. Any suggestions?Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Look at the fuel tank straps for an 18 wheeler (tractor). They have a nice setup with the rig the bolt goes thru to tighten it as well as a hinge on the opposite end. I've seen people use a chain inside a rubberhose, chain welded to one end and a bolt welded to the other which goes thru an angle bracket to tighten.Myself, I go the cheap route and use a nylon web strap and a ratchet binder....Mike
Reply:How about something like this or were you thinking strap? I wouldn't use chain outside, but it's more than strong enough and your's is inside. Just a suggestion. Attached Images
Reply:Originally Posted by trapperjohnHow about something like this or were you thinking strap? I wouldn't use chain outside, but it's more than strong enough and your's is inside. Just a suggestion.
Reply:Here is a tank mount I did for some propane cylinders mounted on the tongue of my brothers concession trailer. Not sure if this will help, but might give you some more ideas to work with. Attached ImagesI am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:If cylinders are to be swapped on an exchange basis, keep in mind that their dimensions can vary.Good Luck
Reply:Originally Posted by denrepIf cylinders are to be swapped on an exchange basis, keep in mind that their dimensions can vary.Good Luck
Reply:why not do somethin like the steel straps on forklifts but modify the brackets to make it stand uphttp://www.hnwelding.com/images/39.jpg
Reply:Originally Posted by wagin. . .I plan on cutting a dual saddle pattern out of 4x4 angle but cannot decide on the hold strapping. Any suggestions?
Reply:Originally Posted by denrepA thought - The angle's narrow edge may tend to "chew" the cylinders.But you already thought of that anyway.Good Luck
Reply:Originally Posted by Notthatlowwhy not do somethin like the steel straps on forklifts but modify the brackets to make it stand uphttp://www.hnwelding.com/images/39.jpg
Reply:That would be what im talkin about there pretty simple to make we did one in ag class in high school for a farmer
Reply:Originally Posted by waginThat's a nice set up. Where did you get the double roller chain with bolt ends? Nice but I think the chain cost would be way over budget.
Reply:I have a design roughed out. Here is where I'm at currently. Attached ImagesMiller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Boostinjdm, I like that toggle clamp on the strap.  Quick and easy.  No looking for a wrench to take the cylinder off.I might add a bolt and nut on the opposite end to allow for cylinders of slightly varying diameter.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:Originally Posted by AndyABoostinjdm, I like that toggle clamp on the strap.  Quick and easy.  No looking for a wrench to take the cylinder off.I might add a bolt and nut on the opposite end to allow for cylinders of slightly varying diameter.
Reply:Here are some process pics and finalized pics. Attached ImagesMiller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
GMT+8, 2025-12-24 20:22 , Processed in 0.068977 second(s), 18 queries .
