Custom Polaris RZR S
发表于 2021-8-31 23:48:35 | 显示全部楼层 |阅读模式
Here is another Polaris RZR that I am building.Cage work is all DOM tubing in various sizes from 1" to 1.75". Sheet metal is all .050" 3003 aluminum.All welding is TIG done with my Syncrowave 250DX.Here is how it started...http://all-a-cart.comWelding Cart Kits and accessories
Reply:....http://all-a-cart.comWelding Cart Kits and accessories
Reply:...http://all-a-cart.comWelding Cart Kits and accessories
Reply:looks really good Paul!!Strive For Perfection
Reply:looks great man. i know of a company that makes a bolt on turbo kit for the RZR if you're into that kind of thing. i rode in one and it was amazing. i'm not too sure if that was a direction you were going to be taking your RZR, but i thought i'd throw that out there. here's their website if you're interested www.aerocharger.com.
Reply:Nice work with the tubing Paul, I have extensive time beatin' on Yamaha Rhinos, this thing looks like its a step above a Rhino. How do they match up, in stock form?Yup
Reply:ZT,Why did you only 'clean' the notched pieces (all the way to really-really shiny!) and nothing on the 'main' tubes/pieces?  The best laid schemes ... Gang oft agley ...
Reply:Hi.    Really top class job. fit up excellent,and welding I can only dream about.  Cheers  Gordon.
Reply:WOW!.  Really great work.  I'm jealous.  I enjoy seeing work from someone with the talent you have.
Reply:Nice work.  Do you drill a small hole near the welds to let the pressure escape?Miller Dynasty 200DX Tig Welder
Reply:Originally Posted by BurnitNice work with the tubing Paul, I have extensive time beatin' on Yamaha Rhinos, this thing looks like its a step above a Rhino. How do they match up, in stock form?
Reply:Originally Posted by mr2manNice work.  Do you drill a small hole near the welds to let the pressure escape?
Reply:Here are some more pics that I didn't have time to post last night....http://all-a-cart.comWelding Cart Kits and accessories
Reply:...Last edited by ZTFab; 03-14-2009 at 10:01 AM.http://all-a-cart.comWelding Cart Kits and accessories
Reply:Nice work partner.  It made me daydream about getting some tig work, its been all fluxcore by the spool for me.DAG NABIT, I left my tape on the saw.Wild Fire Welding
Reply:...http://all-a-cart.comWelding Cart Kits and accessories...http://all-a-cart.comWelding Cart Kits and accessories
Reply:Holy buckets,  how long did this take?DAG NABIT, I left my tape on the saw.Wild Fire Welding
Reply:Originally Posted by Tom KroscavageHoly buckets,  how long did this take?
Reply:ZTFab,  Awsome work! Very nice fit up and weld quality. One question, in post #5 the third pic down, I think I can see that the joint is sleeved, as they all appear to be, and I am in no way questioning the integrity of the weld or the joint, but was curious about the underfill. Is this the norm? I have no experiance in this aplication (off road), and I would guess it is not governed by any code, such as D8.8 automotive and light truck, which I do have experiance in. Again, OUTSTANDING work.PitBull
Reply:Originally Posted by ZTFabI've been working on it after work and weekends since mid January.
Reply:This is truly an amazing work of art. I see that yo ureally take pride in your work and the cleanliness of your shop. Very nice work.AWS CWI/CWEASNT NDT Level 2 PT/MTAWS Certified Welder(aerospace)
Reply:UH, HOLY FREAKING SHEEEEET!!!!That rig is bad azzzzzz!!!!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by pitbullZTFab,  Awsome work! Very nice fit up and weld quality. One question, in post #5 the third pic down, I think I can see that the joint is sleeved, as they all appear to be, and I am in no way questioning the integrity of the weld or the joint, but was curious about the underfill. Is this the norm? I have no experiance in this aplication (off road), and I would guess it is not governed by any code, such as D8.8 automotive and light truck, which I do have experiance in. Again, OUTSTANDING work.PitBull
Reply:ZTFab,  I see now. Really nice work!! PitBull
Reply:ZTFab - Thanks for sharing the pics. It's an awesome project.What wall thickness are you using on the DOM tubing?
Reply:Originally Posted by exothermZTFab - Thanks for sharing the pics. It's an awesome project.What wall thickness are you using on the DOM tubing?
Reply:Thanks. Keep these great posts coming.
Reply:ZTFabyou have some mad skills ,awsome jobChuckASME Pressure Vessel welder
Reply:Great looking build.. I like how you followed the hood line into the dash.  Looks like alot of finish sanding to get fitups like that.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Well, I guess you can make a living in welding OR photography!  Very impressive work. Thanks for posting.
Reply:Another true ZTFab masterpiece Paul.  As always I'll just sit here and keep dreaming.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Wow and here I sit with a kawasaki Mule and Yamaha Timberwold,Exceptional attention to detail wiith fine work on those welds.My hats off to you ZFAB      "oh masterful one"Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Exceptional work as always. One questions for you,the last picture in post #18 shows a smallerdiagonal connected to the main cage. Was that jointwelded before being covered by the diagonal or isthat amount of weld sufficient? The reason I ask is that I am in the process of building a similar cageand really appreciate this design. Thanks again andgreat work.
Reply:Originally Posted by chopper5ZTFabyou have some mad skills ,awsome job
Reply:Got some more welding done....http://all-a-cart.comWelding Cart Kits and accessories
Reply:As amazing as usual Paul. Now he needs more engine, bigger wheels, stronger axles, sturdier clutch, and he´s close to something for a museum.My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:I like the fish finder on the dash .VERY nice work.
Reply:Even in my dreams my welds and work doesn't turn out like that.  It's nice to have something to strive for in my work.
Reply:Paul, it's people like you that are the reason I switched from doing fab work to engineering.  How am I supposed to compete with that?
GMT+8, 2025-12-24 20:32 , Processed in 0.118878 second(s), 18 queries .
