hi all, I'm a newbie looking for a good TIG welder I can do all auto work--including making manifolds, pipe welds, aluminum welds, cromoly cage welds, etc.only requirement is that welder must be able to weld with 115v house current.I've been told to buy dynasty 200dx. while it seems to be just the thing I need, i just thought to ask to see whether there are any cheaper, reliable alternatives.thanks!
Reply:For an AC TIG machine that runs on 110 volts, the Dynasty 200 is the only one I can think of. Maybe HTP has one that runs on 110v, not sure. In any case, you won't be welding much of anything thick in aluminum with 110 volt power.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:You're better off having your house rewired. You will not have enough amperage to fabricate heavier aluminum sections of manifolds as you're describing, i.e runners to flanges. If you're not welding heavy aluminum sections, the 200DX will do just fine.
Reply:200 DX, but as mentioned your going to be limited on 115V. Just curious, how much welding experience do you have, honestly? Knowing this may better help us to help you. |
