Looking for help making folding table legs
发表于 2021-8-31 23:48:28 | 显示全部楼层 |阅读模式
I have a decent piece of wood that i would like to make into a camping table to put the stove on and would like to make folding legs fairly easy, any ideas?Thanks
Reply:maybe you could give us some more information.  how heavy is the stove, how tall do you want it, etc etc.  If you want basic folding table ideas, just google "folding table" and get some ideas.Millermatic 135Syncrowave 250
Reply:I would buy a set from HF. They are cheap and just screw onto wood.
Reply:are they on hf's website? i want it about 4' high its just a coleman propane two burner stove, not heavy.
Reply:ok i see them, i though i looked at hf before guess not, thanks
Reply:i went to get them and they are only 28" tall no good
Reply:Originally Posted by Pandemoniumi went to get them and they are only 28" tall no good
Reply:What norite said. It will still be better than having to build them.
Reply:i dony have any metal to add to those legs, but i could build the table bottom up with more wood.
Reply:i would say just make a set of screw type legs it would be just as easy but thats just me
Reply:Originally Posted by Notthatlowi would say just make a set of screw type legs it would be just as easy but thats just me
Reply:Getting the "4 bar" system to work might be a pain, especially if you aren't willing to fabricate.  For my wooden workbench I put two bolts on each leg holding it to the top.  That way, if I am moving, which I seem to do frequently, I can take all 4 legs off easily and everything is compact.  I've attached photos of my very first garage setup out of college at my apartment : ) or should I say : (. Regardless, this design my be interesting to you. Attached ImagesLast edited by engineer1984; 09-21-2010 at 05:49 PM.
Reply:4 of dees and 4 pieces o' pipehttp://www.homedepot.com/h_d1/N-5yc1...atalogId=10053Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-24 20:22 , Processed in 0.093510 second(s), 18 queries .
