bracket
发表于 2021-8-31 23:48:27 | 显示全部楼层 |阅读模式
Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:step 2 3 4Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:The original design of this Parabolic Lighting reflector has the Light held by the Aluminum ring you can see in the center and is Fixed in that position.A client of mine asked if I could come up with something so that he could relocate the Light out away from the rear and also be able to move the Light in and out to control how the light falls on the subject.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:That's a pretty neat bracket and should do everything he needs it to. I kinda pictured the light shining away from the parabolic umbrella but I see it shines into it and reflects back out. What effect does that do, soften and spread the light??"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Nice!-Wish I could weld like you...
Reply:Say Cheeeeeeeeeeeeeeezeeeeeeee!...zap1I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:That particular set up is supposed to mount from the back and a diffusion silk covers the front but the mo' money reflectors put the head out in front of the reflector and he'll cut a silver disc to cover the now existing hole.http://www.profoto.com/products/ligh...ant-reflectorsYou can see the various sizes- The silver Arm is a standard Photo/film/grip item with a 5/8" rod so readily available anywhere. I told him 20 bux( I was bored at work) he gave me $35.00 but I know I can make a couple more for folks that have the same Light Modifier.This guys used a whole bunch of clamps to do the same thing and in teh Studio no big deal but on location less is more.http://www.msegrip.com/1stblog.htmlEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:suuurrrrree, its a "parabolic light reflector"  I know someone is trying to phone home when i see it.  You're in LA, and i'm only about 40 miles east of you, I'm putting on my tin foil hat, just in case you aim that thing my way.aren't motion/still camera related stuff just outrageously expensive?  I see a lot of homebrew "adapter plate, light-stands, swivel mounts and so on" that are really nicely designed, while a lot of the off-the-shelf stuff is just expensive because it was powdercoated.your design is definitely a lot better then the production ones you linked.
Reply:Originally Posted by oxy moronaren't motion/still camera related stuff just outrageously expensive?
GMT+8, 2025-12-24 22:28 , Processed in 0.090927 second(s), 18 queries .
