humidity in rods
发表于 2021-8-31 23:48:19 | 显示全部楼层 |阅读模式
HiI bought a box of Phoenix 7018 rods (250 rods) and the last ones, half a box are humid, when i weld they make a strange sound like an explosion and they get hard to open arc.How can i dry them or conserve then when i buy another box since i dont have a rod oven.Can i use a kitchen oven to dry them ???Thanks.
Reply:Sure can.  250-300 degrees F for 1-2hrs as Sam points out here http://weldingweb.com/vbb/showthread.php?t=30399 in post #14.Just make sure the Mrs. isn't expecting to use the oven at the same time.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-24 22:10 , Processed in 0.102318 second(s), 18 queries .
