Lincoln Power Mig 180C K2473-1 vs K2473-2 Is there a difference?
发表于 2021-8-31 23:48:15 | 显示全部楼层 |阅读模式
I see both listed on Lincolns website for the same price but no explanation and nothing that explains the differences. Is there anything different about the two?
Reply:from what i've heard rumor is the number 2 at the end means its the newest model and has a different gun,which is not adaptable to old ones for replacement,which just means no aftermarket replacement for it for now,but i'm sure there will be soonLincoln Ranger 8 225Lincoln 180 ProMigMiller Maxstar 200DXInternational Ironworkers Local 70930+ years and counting
Reply:I had the same question and contacted Lincoln. They responded quickly.The K2473-1 comes with the standard Magnum 100L Gun.The K2473-2 comes with the new Magnum Pro 100L Gun which use the Copper Plus consumables.Hope this helps
GMT+8, 2025-12-24 22:10 , Processed in 0.069979 second(s), 18 queries .
