Esab 215 question
发表于 2021-8-31 23:48:14 | 显示全部楼层 |阅读模式
Does anyone here have any experience with the esab 215 migmaster pro? If so does it have infinite voltage settings or is it tapped? Also have you had any issues with it?
Reply:I have not seen that one but just looked at a 280 at my LWS today. Its tapped so I am guessing. The 215 is also.    There are enough taps that it will work as well as an infinite adjustment machine for most stuff.     If u are using a non digital readout infinite machine its probably actually better as each tap is exactly the same voltage each time u use it.   With no readout on the other u are just guessingTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-24 22:10 , Processed in 0.092852 second(s), 18 queries .
