Jackson 370 headgear..??
发表于 2021-8-31 23:48:14 | 显示全部楼层 |阅读模式
Has anyone tried the new Jackson 370 head gear?  It fits all HSL100 and Halo-X hoods.  I was wondering if it's better than the standard Jackson headgear.  The info says it keep the hood in the up position better.  That would be worth a try for me.  It looks like it might be better than the ones I have.http://www.jacksonsafety.com/linkdet...roupid=3014866MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:It sells for about $10-12 at most online places I found it at.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Where did you find it? Im having trouble finding it. I love my jackson hood but I need a new headgear the original one is about worn out and it droops and the adjustment screws just spin. I will buy it, and report back once I get it.If you cannot convince them, confuse them.         Harry S Truman
Reply:I went and ordered it today at Airgas after posting this, figured I'd take a chance on it.You can read about it on the Jackson website, which I linked to in the first post.  As for finding it online, I just typed 'jackson 370 headgear' into Google and a few online weld supply sites popped up, with pricing.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:UPDATE!Well the 370 arrived and I went and picked it up and used it a little today.  IT WORKS GOOD!  The detents in the rotating mechanism definately keep the hood in the up position without falling down!  Finally!  The thing is designed so the knob tension only adjusts the speed the hood comes down and doesn't have anything to do with keeping the hood up.  The detents keep the hood up.   The head gear is also very comfortable on the head.  I like wearing it better than the original one.  Finally the EQC has a headgear worthy of the hood and lens it supports!    I'm going to order another one too for my other EQC hood.   Hopefully the local shop will start stocking these, as I could turn a few friends on to them too if they try out my hood with the new gear.Jackson should eliminate the current stock headgear and start supplying this new headgear with all new auto hoods!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Well, mine will be here Monday, so I'm glad to hear you are happy with yours. I will post some pics for everyone so they can see the difference. I agree Jackson needs to ditch the old headgear if this is as great as you make it sound. I will report back someitme next week.If you cannot convince them, confuse them.         Harry S Truman
Reply:It's definately a big improvement!  MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Let us know what you think of that headgear, Silverado.   I let my friend borrow my hood with the new headgear for a job he did last night.  He said he likes it alot better than his old Jackson headgear and ordered one for himself.   I'm going to get a couple more for my other Jackson hoods too, they're cheap enough to splurge a little even though money is tight now.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I grabbed one of these last week...The hood I put it on is fairly heavy.  HSL with glass filter plate, two clear plates, and a leather bib.  The normal headgear didn't stand a chance of keeping it up.  With the tension tight enough to keep it up, it took two or three nods to flip it down.  With the 370 headgear it stays up no problem when snapped into the up detent.  The detent is deep enough to keep the hood up even while moving my head around, but a plain old nod that ever welder knows is enough to get it to flip down.  It also has three position adjustment for how close to your face the hood comes.  If you're having problems with your Jackson hood not staying up, then this headgear is a good buy.
Reply:I know this is an old post, but how are yalls head gears holding up?I've been through 3 in the last 16 monthsThey keep tearing at the pivot point on the left side.
Reply:Hey bud I've dealt with the same thing since the 370 came out. I have probably been through 3 or 4.Miller Bobcat 250Westinghouse ac arc welderIts better to be hated for who you are than liked for who your not.
Reply:Not what I wanted to hear, just got my truesight, and Frankensteined the 370 head gear into 4 other hoods...  guess I need to pick up a couple sparesWhen any government, or any church for that matter, undertakes to say to its subjects, "This you may not read, this you must not see, this you are forbidden to know," the end result is tyranny and oppression, no matter how holy the motives.
Reply:I have the same one and you WILL be doing this...http://weldingweb.com/vbb/showthread.php...highlight=Mask...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-25 00:01 , Processed in 0.102800 second(s), 18 queries .
