Wall Mount Handrail Project
发表于 2021-8-31 23:48:08 | 显示全部楼层 |阅读模式
Just alittle handrail that mounts on the side of the wall to use when walking up steps. Materials2''x 3/16'' Flat Bar1''x1/2'' channelThe bending jig All BentLayout on the channel for the mounting bracketsHoles drilled and tapped 1/4 20The mounting bracketNow lets start tacking the channel on the flat barAll tacked upWell thats all for now. I will finish welding it up tomorrow. Thanks for looking Ya gotta spend money to make money!
Reply:All welded upScratch Start around 80 amps3/32 Red1/16'' 70s6 #5 nozzleDidn't hold it at the end long enough to fill the craterAll doneNow ready to clean up and shoot it with primer!Thanks for looking!Ya gotta spend money to make money!
Reply:Looks pretty spiffy, well done
Reply:i am concerned that the 20 thread per inch bolt will only catch about 2 threads in the 1 x 1/2 channel....?
Reply:Yup, that was my conceren too. I was going to weld a nut behind it but i figured i would try to tap it first. Its actually a 3-4 threads. I put the bolt in and cranked them down and everthing was fine.Ya gotta spend money to make money!
Reply:Looks nice.For future hand rail work, most ornamental metal suppliers sell weldable hand rail wall mounts.  Alot faster/cheaper to just weld them on than drilling/tapping/bolting and a stronger connection as well.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-24 22:29 , Processed in 0.091467 second(s), 18 queries .
