7018 1/2" fillet up
发表于 2021-8-31 23:48:07 | 显示全部楼层 |阅读模式
I was welding on a tower today.   Just took one pic.  I am sending a copy to my customer.WPS calls for 1/2" fillet vertical up. I made 2 passes, 1/8" 8018  125 amps.  I opened the 50 lb can this morning.Plate on left is 1" grade 50.  Tower is 3/8" with galv ground off.Ummm Lincoln rod and Lincoln machine  DavidLast edited by David R; 05-12-2009 at 10:05 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:You mean you weld on towers without any snow blowing down your neck?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Isn't that pretty, but you did give him something for nothing, haha.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:Yup, a 1/2" fillet is pretty darn big and a LOT of filler.1/4" stick at 300-350 amps maybe?7018 or 8018?  Your title says 70 but the posting said 80.  Not that it matters a whole lot for the fillet size.  The best laid schemes ... Gang oft agley ...
Reply:moonrise, 1/8" 8018 125 amps.   I can't weld vertical up with anything bigger than 5/32.I burned 15 lbs yesterday.  Those ups go slow.  I get about an inch from one rod on the second pass.  There are 3 starts and stops in that picture.NO duane, no snow!  Just sunshine and a little breeze.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I hope that doesn't have to be painted ! Someones gonna have to rough it up some . Too SLICKHave a nice dayhttp://www.weldingdata.com/
GMT+8, 2025-12-24 22:28 , Processed in 0.065965 second(s), 18 queries .
