Abicor Binzel Tig Torch
发表于 2021-8-31 23:48:07 | 显示全部楼层 |阅读模式
Finally got a Tig welder, Thermal Arc 160TS, got it used off ebay. The tig torch that came with it is a benzel sr-24, and I dont think that this is what comes standard with the machine.it looks like this:I dont know what kind of torch this is, it doesnt have a back cap and only has space for about an inch of tungsten. it also has a weldcraft gas cap on it:if i wanted to replace this with say a weldcraft wp17 torch do I just unscrew the wire and gas line here and just screw on the new torch?
Reply:whydo you  need more than one inch of tungsten?(just kidding)...
Reply:Or you could just put a highback on as that button thing should be removable and a bigger defuser and ceramic, otherwise you will be able to unscrew it there and away you go.Last edited by wirehunt; 05-13-2009 at 08:00 AM.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:Originally Posted by weldbeadwhydo you  need more than one inch of tungsten?(just kidding)...
Reply:Originally Posted by wirehuntOr you could just put a highback on as that button thing should be removable and a bigger defuser and ceramic, otherwise you will be able to unscrew it there and away you go.
GMT+8, 2025-12-24 22:29 , Processed in 0.098798 second(s), 18 queries .
