progress.....tig
发表于 2021-8-31 23:48:02 | 显示全部楼层 |阅读模式
some of you might remember, i was trying to teach myself oxy/acet welding.  I built a welding table, a front gate, and a utility cart all gas welded.  Well, that was until I bought a Miller Syncrowave 180.  it wasn't as difficult as i expected, I suspect it's the experimentation with gas welding that helped.  that was enough to get me started,  But having a mentor showing me the ropes in what the puddle was suppose to look like, tips/tricks on fillet, metalselection DEFINITELY helped a lot (thanks a bunch Paul).anyway, i've moved on to tig welding because torch pops scares the heck outta me!  Oh, i'm keeping the gas torchesand bottles (almost empty) around, just in case.  but tig welding is such a gentleman's process... so civilized!  so civilized compared to my moronic attempt at gas welding anyway.following is a couple of stainless steel, i dont know what gauge.  they're just tacked together and fusion welded.  no filler rod (except for the tacks).machine setting as follows:55amps (was welding 1/16 square tubing, and i didn't bother to change it, just "feathered" the pedal)i guess thats about it, syncro 180's pre/post flow aren't adjustable (1/2 second pre, and 18 seconds of post)100% argon set at 20 cf/hri'd take any advice and constructive criticismsLast edited by oxy moron; 05-17-2009 at 02:35 AM.
Reply:Nothing bad to say about the weld.  The bead on the back side says it all.Ditch the bic lighter!David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Yep, it looks like you have that sorted Why ditch the lighter David?  Is it French?????I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:John!!That is amazing progress since you were at my shop. Nice job! ...and just so you know, the SS I gave you is 16ga 304.- Paulhttp://all-a-cart.comWelding Cart Kits and accessories
Reply:I don't like bic lighters and welding.  A spark could burn through the plastic pretty easy.To each his own.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Looks like your well on your way."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:Having a BIC lighter in your packet or around you while cutting/welding is just like having a 1/4 stick of dynamite in your pocket, If I get caught with one at work it is instant termination, and every once in a while a boss walks up to ya and asks for a light for his cigarette, but it is dangerous
Reply:It is in fact awesome that you are able to take advantage of Paul's generosity.  His work tells me you couldn' t find a better mentor.  Nice work.As for that postflow, what vintage 180 SD do you have?  Mine is adjustable from 5-18 seconds as part of initial set up.  Usually set it for 1sec/10amp anticipated.  Preflow - no, postflow - yes.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, I don't know what version my 180sd is, all i know is that its made in 2000.I did use the serial number to download a PDF manual.  and it says pre/post flowis not adjustable.  however, if there's a hack, please enlighten me.its hooked up to that Tweco cooler/torch (which has now been moved to BELOWthe welder).Last edited by oxy moron; 05-17-2009 at 10:13 PM.
Reply:BIC lighter was used in lieu of dimes.  since i didn't know that the stuff i have was 16 gauge, i thought i just used whatever i had around.  No worries, guys, smoke break area is nowhere near the welding area.  pic was taken after all the welding was done and everything put away (2 car garage, 1 man show).  easier to grab a lighter then go inside and dig around for dimes.
Reply:Originally Posted by oxy moronDuane, I don't know what version my 180sd is, all i know is that its made in 2000.I did use the serial number to download a PDF manual.  and it says pre/post flowis not adjustable.  however, if there's a hack, please enlighten me.
Reply:Let me know when you need more material to practice on.http://all-a-cart.comWelding Cart Kits and accessories
Reply:Originally Posted by ZTFabLet me know when you need more material to practice on.
GMT+8, 2025-12-24 22:27 , Processed in 0.068709 second(s), 18 queries .
