ranger 8 and mig question
发表于 2021-8-31 23:47:58 | 显示全部楼层 |阅读模式
I have a ranger 8 and would like to set it up for mig to do aluminum or steel. all i need is a spool gun so the ?. I like the profax system and read for miller and holbart its plug and play, can it be used on the lincoln ranger 8 without alot of rigging, i'm a one wire hook it up, two wire's mess it up, lectrician. I'll be using it for personal use auto body ,trailers, and farm work and everything the neighbors can drag over. any other suggestions would be appreciated thanks
Reply:yep you  can do that, just set the ranger 8 to CV mode,  I have a profax with controller that would be basically plug and play for sale HEREjust plug it into one of the 110 outlets on the ranger 8 and hookup your gas.  ready to go  PM me if interestedTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-24 22:27 , Processed in 0.071934 second(s), 18 queries .
