查看: 13|回复: 0
Garden Tractor Snow Blade
发表于 2021-8-31 23:47:55 | 显示全部楼层 |阅读模式
I would like to build a blade for my garden tractor. Dose any one have plans or pitchers?    Would mostly like to see the spring tightiner asembly and the raising lever.                       Greg
Reply:I have pitchers but they are for beer. LOL !!!!!!!!!Sorry I couldn't help myself Miller 330 A/BP Bernard SS coolerMiller cst 250Miller Big Blue 251DCentury 210 Mig (first welder I bought)Hypertherm PowerMax 800Victor torch setRu Fong 31 MilAtlas lathe
Reply:here's a blade that started out for a garden tractor and was modified to fit a quad. Latest modification  is power angle.Sorry no lifting, that's now done by an electric winch. Attached Images
Reply:I know you want to build your own, but for my money, I'd find a good used or new plow like is made for 4 wheelers and adapt it to fit. They are lite yet tough as nails. When I lived up in Idaho I had one on my wheeler with an elec. winch to raise and lower it. I also fastened a 3/4" dog leash to the drum w/ the loop end attached to the plow w/ a small shackle and the cut off end attached to the drum w/ a small self drilling screw, just make sure you have 3 or 4 wraps around the drum before the line tightens up. This worked a lot better than the cable that was always piling up and working to destroy itself.                                         HTH,                                                MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Thanks guys for the help. I can buy one for $300 or a little moore dut I like to                                build things. I though this would be a good and maybe sum others would like                                    to build too.        Greg
Reply:Originally Posted by Greg LakoThanks guys for the help. I can buy one for $300 or a little moore dut I like to                                build things. I though this would be a good and maybe sum others would like                                    to build too.        Greg
Reply:This one is made from an old hot water tank. Should be enough detail to get you started:http://www.mytractorforum.com/showthread.php?t=67335
Reply:At the end of snow season my son talked the salesperson at Lowes into giving him good deal on a blade so he bought one before I could build it. So on to the next project ?????  Thanks to all those that tried to help. Greg
GMT+8, 2025-12-25 00:01 , Processed in 0.142923 second(s), 18 queries .
