Couple pics from tiggin
发表于 2021-8-31 23:47:52 | 显示全部楼层 |阅读模式
Just about finished up with my GTAW pipe welding.Decided to take the day and play around a little.Mixture of 3/32nd and 1/8th wire.Freehand on the side.Walking the cup on the top section.Any tips or pointers? How's it look for my first time?1981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
Reply:The ones where you walkeed the cup look decent. Your free hand bead looks about 20 amps too cold. On your free hand beads try dipping your filler in and out of your puddle while preceding along with your torch
Reply:Freehand has poor tie-in on the sides (i.e. cold lap/lack of fusion).  Turn the amps up and work the arc some on the sides in order to tie in.  Definitely work more on freehand as you cannot always walk the cup with pipe and tubes.Engineer/CWI/Welder
Reply:Thanks....Exactly what I was after....Appreciate it.1981 Lincoln SA 200Miller Trailblazer 302gMiller 211 Mig Welder w/ AutosetI'm learning to stick metal together
GMT+8, 2025-12-25 00:00 , Processed in 0.104376 second(s), 18 queries .
