Started Welding School
发表于 2021-8-31 23:47:51 | 显示全部楼层 |阅读模式
Just started welding class offered by http://www.ouboces.org/ .  Below are pictures from my 2nd class using 7018 1/8" rod set around 100 amps (gauge is missing) in flat position. To me it looks good but I am open to suggestions and tips. I am having trouble in verticle up. See last pic. Attached ImagesMiller Maxstar 150 STLMiller Trailblazer 302Lincoln Classic 3DMiller Suitcase x-treme 8VSMiller Spoolmatic 30A
Reply:Originally Posted by jamo1911Just started welding class offered by http://www.ouboces.org/ .  Below are pictures from my 2nd class using 7018 1/8" rod set around 100 amps (gauge is missing) in flat position. To me it looks good but I am open to suggestions and tips. I am having trouble in verticle up. See last pic.
Reply:Your vert. up looks good from the start til about the 1/2 way point.From there your moving to fast.Try getting the work higher up so the rod isn't blocking your view of the puddle. I also run my 7018 up at about 110-120
Reply:Practice Practice Practice Practice When your done practice more. Does not look to bad for just starting.Miller 330 A/BP Bernard SS coolerMiller cst 250Miller Big Blue 251DCentury 210 Mig (first welder I bought)Hypertherm PowerMax 800Victor torch setRu Fong 31 MilAtlas lathe
Reply:Pretty good start. Dont beat yourself up. It can be very frustrating at times. Save a coupon in your locker or somewhere and dont look at it for 3 or 4 weeks. Then pull it out on a day when you think you're not getting anywhere. You will see that you are progressing.Have funUA Local 598
Reply:Thanks Guys, I appreciate the kind words.  We had a week off because of something to do with the shop getting the air hoods repaired. But we get to make it up later.Miller Maxstar 150 STLMiller Trailblazer 302Lincoln Classic 3DMiller Suitcase x-treme 8VSMiller Spoolmatic 30A
Reply:Originally Posted by WHughesPretty good start. Dont beat yourself up. It can be very frustrating at times. Save a coupon in your locker or somewhere and dont look at it for 3 or 4 weeks. Then pull it out on a day when you think you're not getting anywhere. You will see that you are progressing.Have fun
GMT+8, 2025-12-24 22:27 , Processed in 0.094899 second(s), 18 queries .
