Like the moon
发表于 2021-8-31 23:47:49 | 显示全部楼层 |阅读模式
I'm building a drag to pull behind my tractor and I was butt welding some 10ga sheets together.  These will be in a non visible location and since I was running low on C25, I decided to do them with CO2. I needed the Argon for the exposed finish welds on top.   I grabbed the CO2 bottle, but couldn't find the CO2 regulator.  I found the adapter to fit the Argon regulator and hooked everything up and off I went.  I go about 2' of nice bead laid down and then snap-crackle-pop!The regulator froze up and I had 4" of weld that looked like the craters on the moon.Get out the grinder, find the proper regulator, do over.  Grrr... Attached Images
GMT+8, 2025-12-24 22:28 , Processed in 0.070269 second(s), 18 queries .
