Arc Welder barnds to avoid!
发表于 2021-8-31 23:47:47 | 显示全部楼层 |阅读模式
Hey all im new here, im from australia and im looking at getting an arc welder for at home jus to mess around on, i don't have access to 3-phase power so a single phase is gonna have to do. My question is, as im on a bit of a budget il proly end up getting a second hand one and im just wondering are there any brands of arc welders to avoid? Or Any suggestions on which brands people would reccomend.Any input would be much appreciated.
Reply:Theres lots to avoid. But i suggest you get a Lincoln Tombstone!ShaneYa gotta spend money to make money!
Reply:You'll be fine with just about anything from Miller, Lincoln, ESAB, Hobart, Thermal Arc or HTP.   Avoid the cheap Chinese junk.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Are you wanting MIG or stick?  I agree completely with DesertRider   buy a name brand.   There are a few others if you are on a budget & buy used.   Repair parts may not be still avalible but on stick welders you can throw in Airco, Westinghouse, older Hobart Brothers, Marquette.    If you can test it before you buy. There just isn't much that goes wrong with a stick machine.  If the $$$$ is low then so is the risk.IF IT WORKS, DON'T FIX IT2 Lincoln CV-300 / LN-7 GMALinde-VI 253,400 & 450 w/MIG35 feedersCNC Table with Oxweld O/A & Hypertherm 1250G3Lincoln Ranger GXT 250Hobart-MicroWire 300ESAB Heliarc 161ESAB-Mobilemaster 2 CC/CV Feeders& more
GMT+8, 2025-12-25 00:01 , Processed in 0.130463 second(s), 18 queries .
