Mig Conversion on the Lincoln 100HD
发表于 2021-8-31 23:47:45 | 显示全部楼层 |阅读模式
I have a Lincoln 100HD and want to try converting it to MIG with their K610-1 conversion kit.http://www.mylincolnelectric.com/Cat...et.aspx?p=7115My question is it worth being cheap and buying the parts separately or just getting the kit with instructions? I've found the kit as low as $121 with free shipping online, but could I really save by buying the parts myself? I also downloaded the kit contents from Lincoln so I know what the part are. Contents http://search.lincolnelectric.com/cs...coln&n=1&la=enThe only thing I can't find online are the actual instructions to install the conversion, so I might have to buy the kit just to get the instructions anyway if I can't find someone with the instructions because I'm not that familiar with mig setups.Any thoughts? Anyone have the instructions for this conversion?ThanksTK
Reply:I can't speak for that model but I bought the kit for my weldpak 155 because I got a great deal on them. I had an older 120 volt century that I converted by just buying a soleniod valve and a regulator. This set up had the valve on th regulator. Both ways worked fine. Don't forget to switch the polarity, otherwise it's pretty self explantory.Tough as nails and damn near as smart
Reply:Hey Throttleking!I'm in the same situation you were in!I have a Lincoln Weld Pak 100 and I did buy the K610-1 Mig Conversion Kit but lost the instructions on how to install the kit.Can you help me?Either print out the install instructions on this site or send it to me via my email:[email protected] waiting impatiently for your reply!Thankyou very much!!Ned Ontai
Reply:Lincoln had machine manuals in pdf file free download.   Is it not covered in the machine manual??  If not Call Lincoln's customer service hotline.  I'd almost bet they will email you a .pdf file of the kit instructions.IF IT WORKS, DON'T FIX IT2 Lincoln CV-300 / LN-7 GMALinde-VI 253,400 & 450 w/MIG35 feedersCNC Table with Oxweld O/A & Hypertherm 1250G3Lincoln Ranger GXT 250Hobart-MicroWire 300ESAB Heliarc 161ESAB-Mobilemaster 2 CC/CV Feeders& more
Reply:I have the Lincoln 100HD, and the only way I would convert it to gas is if I used it for a lot of sheet metal work (auto body or the like). There just isn't the power there to go to gas for me.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:http://content.lincolnelectric.com//...r/im/IM780.pdfit's in the original welding manual.  I'm not sure the kit contains any new information. Originally Posted by nontaisterHey Throttleking!I'm in the same situation you were in!I have a Lincoln Weld Pak 100 and I did buy the K610-1 Mig Conversion Kit but lost the instructions on how to install the kit.Can you help me?Either print out the install instructions on this site or send it to me via my email:[email protected] waiting impatiently for your reply!Thankyou very much!!Ned Ontai
GMT+8, 2025-12-24 22:11 , Processed in 0.096176 second(s), 18 queries .
