electrical
发表于 2021-8-31 23:47:43 | 显示全部楼层 |阅读模式
what size wire and breaker do i need to hook up a lincoln weldpak 175hd ....230v is straight argon ok or do i need co2 or 75/25 mix. the only mig welding i have done in the past was with 7/64 flux core wire. thanks for the help.
Reply:There is a boatload of information on this forum about wire size and breakers. Go to the Electrical section and start searching and reading. Typically for MIG on steel you will want to use 75/25.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Originally Posted by railroaderwhat size wire and breaker do i need to hook up a lincoln weldpak 175hd ....230v is straight argon ok or do i need co2 or 75/25 mix. the only mig welding i have done in the past was with 7/64 flux core wire. thanks for the help.
Reply:look at the label on the backup to 30 amps is #10 wire and a thirty amp breaker30 to 50 amps is #8
GMT+8, 2025-12-24 22:29 , Processed in 0.093391 second(s), 18 queries .
