WhEre to buy bar and fin material.
发表于 2021-8-31 23:47:41 | 显示全部楼层 |阅读模式
Hey fellas,As the title states I am looking for aluminum bar and fin material to build a water to air intercooler. I found it in the past on fleabay but can't seem to find it now. I was wondering if anyone knew of where to purchase the stock without end tanks.ThanksMiller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:I'd recommend also looking at bell intercoolers, they can build you a core in just about any size/config that you want and then you just build your own tanks... the cores are pretty reasonably priced too, might not be worth building your own...miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:Thank you I will look into itMiller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Spearco and Garrett also make intercooler cores of various sizes.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:yeah, they do make some, and you may get lucky and find something close to what you are ideally looking for but they only make a few standard sizes and even fewer air/liquid , where bell actually can make you just about anything you desire in exactly the size you want. pick the core thckness and then height and width, they claim to have over 3,000 different sized cores in stock. I haven't found anything close to this versitale with any other supplier  http://www.bellintercoolers.com/_pag...iquidCore.htmlmiller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:siliconeintakes.com has some really inexpensive air/water units.Hobart EZ-Tig newbie.
Reply:Thanks you fellasMiller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
GMT+8, 2025-12-24 22:28 , Processed in 0.071866 second(s), 18 queries .
