Need some help with parts for Lincoln SA-200
发表于 2021-8-31 23:47:40 | 显示全部楼层 |阅读模式
Ok i started to tear down everything on the SA. The radiator leaks but im going to try to fix some of the spots. I would like to get new hoses also.Here are the only hoses i found. it would be $47 with shipping. Is that good or to much...if so where should i look at or find cheaper ones???http://www.ebay.com/itm/Lincoln-SA-2...item5ae7f42959Next....the radiator is about $330 new...is that good or to much as well? Is there a place around Ann Arbor Michigan where they fix them or re-core them? Or a better place to buy one online???http://www.ebay.com/itm/NEW-RADIATOR...item564b439cccThanks for the help guysHere are some pics of the tear down.Lincoln SA 200 Lincoln Idealarc 300/300 TIG
Reply:There is a guy up in my area (Oregon) who sells some SA200 parts. Contact him here--- http://www.ebay.com/itm/NEW-RADIATOR...item564b439cccAsk him if he can give you a better price if you buy it "direct" from him (avoid eBay fees). On the hoses you can take the old ones to your local NAPA store and they can match them to some very similar hoses. Unfortunately, that will probably cost about as much as the other hose kits at bill's Welder repair or Stumphs.Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:ok thanks! Originally Posted by hobohiltonThere is a guy up in my area (Oregon) who sells some SA200 parts. Contact him here--- http://www.ebay.com/itm/NEW-RADIATOR...item564b439cccAsk him if he can give you a better price if you buy it "direct" from him (avoid eBay fees). On the hoses you can take the old ones to your local NAPA store and they can match them to some very similar hoses. Unfortunately, that will probably cost about as much as the other hose kits at bill's Welder repair or Stumphs.
GMT+8, 2025-12-24 22:29 , Processed in 0.094553 second(s), 18 queries .
