Couple carts for work
发表于 2021-8-31 23:47:36 | 显示全部楼层 |阅读模式
Just a simple Cart/rack for folding chairs.16g tubingooh ahhh paintEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Flat cart for moving misc. equipment.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Nice carts. They are handy to have around and I'm figuring out some for my own use.
Reply:Lookin' good EdPerfect for moving beer kegs"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammLookin' good EdPerfect for moving beer kegs
Reply:Ed,A suggestive thought popped into my head for your chair rack.I'm not an experienced professional chair mover but I have moved that exact style chair a couple times and always found it easiest to run your hand down the top of the chair to lift as many as will fit up to your elbow and go (orange arrow). It looks like your design has you lifting the chairs up and out the center of the rack which may be difficult and exhausting.If you made the horizontal and vertical bars on one end removable (yellow lines) you may find loading and unloading to be quicker and easier (black arrows).Just a thought.Also note I marked up your unpainted picture so I wouldn't scratch your fresh paint job  Attached Images
Reply:Removable parts get lost when out on a rentalI just copied a cart that is on the market and used quite a bit in the Film biz. Their cart holds 60 chairs I don't rent as many chairs as these guys, heck I rent from them when I need more.http://www.line204.com/categories/pr...n-rentals.html Attached ImagesEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Hi Broccoli 1  I recently realized you do rentals for venues/concerts etc.  Do weddings, lots of food, everyone is happy, and the "scenery" in nice too. ?  I had two carts which were heavy wood with good 360 degree rotating rollers, size?  like about a 30"x30" flatbed kinda' thing.  You could put speakers, amps etc. on them and they had two heavy ropes tied underneath, one at each end. With two guys you could work them and go up over bumps, spin them without hitting walls etc.. very handy.  Fabricated out of metal, with your expertise even better. enjoy,  ps: I'm available for roadie work at any celebrity weddings you doLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Our business is the rental of Photography equipment and support equipment for the photo shoots. Lights, Cameras, DigitalGenerators, electrical distributionTables, Chairs, Ez Up Tents Trucks & Vans for the equipment Our clients are primarily Still Photographers so not much motion and no Audio/concert- those guys are in a different rental world.www.screamingbroccoli.netYou can see some of our clients' work- either shot here at our Studio or on location with the equipment provided by us.Event rentals at our Studio: they will bring in their own crew to set up & breakdown. We just charge a Flat rate on the space. Event companies have that sheite dialed in with Tables, Chairs, Linens, Tableware etc.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Boys put the Cart to the test today50' #2 cable "banded" together- just taped together every foot or so but 5 pieces so da stuff get heavy.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:not a welding qustion, have you had the opportunity to be on any Ken Marcus shoots?
Reply:Originally Posted by Ron Padillanot a welding qustion, have you had the opportunity to be on any Ken Marcus shoots?
Reply:Looks good, Ed.   Those air tires in the last couple pics of the flat cart are lookin a little overloaded with all that welding lead on there.   That's alotta weight!  Maybe you need some LT, E-rated cart tires!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Dern cheap HF Hold No air tiresand that is not welding cable....we have to use Entertainment cable don't remember when they changed the Code but No longer allowed to use welding cableget yer pee pee smacked by LAFD iffin' they catch youEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:If you dance and sing while using the welding cable, does that make it 'entertainment' cable???MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33If you dance and sing while using the welding cable, does that make it 'entertainment' cable???
Reply:So how well do they work on the welder Ed? .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I used to have a guy visit my shop. He was a big time  pro photographer, who did a lot of high $ shots. At the time he was married to a Dr. here.  One day he walks in and tells me he had just finished doing pictures of Stevie Nix, with a Grand piano behind her... for Christmas I think.  He always seemed a little iffy, so I took it with a grain of salt.  Jokes on me, he brought me a 5x7 about a week later. She's spacey but I like her voice, and the rest of here ain't bad especially in the early days. Those carts look real handy, ya' done goodLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
GMT+8, 2025-12-24 22:11 , Processed in 0.094989 second(s), 18 queries .
