problem with bender
发表于 2021-8-31 23:47:35 | 显示全部楼层 |阅读模式
Can't seem to get this thing to work a damnEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Prayer works really good for meLincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:Just funnin'Makin' a flower stalk fer da Mrs.temp set up for the 2020 benderEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:A roller would be Mo' better but I ain't got one for Tube so Kink-o-matic it is.Works Great for what it is supposed to do Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I like that bender "mount" Ed.  Got a " in the WW 1 trenches, and need to bend this bar........HEY....Who's Haussfeld is this??????? " look to it. I bend this type of thing lots, but use plywood/ pipe rounds bolted to my bending table. Post when you get it done!Bert200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
GMT+8, 2025-12-24 22:29 , Processed in 0.228638 second(s), 18 queries .
