Another Weld critique
发表于 2021-8-31 23:47:33 | 显示全部楼层 |阅读模式
Still learning just would like some advice, using my friends flux Lincoln haven't bought my own yet thank you
Reply:I am seeing lots of undercut, incomplete fill.In the second photo I see too much fill at the bottom not enough at the top.In general travel speed erratic and too slow. Make small circles and allow the joint to fill more.
Reply:ok ill try that i do slow zig zags what do you mean circles like diagonal half moons
Reply:Circles, like circles.  You look like you are getting the process down.  Just take your time, slow down a bit, and keep a steady consistant speed.  You are definitely on your way!
Reply:Which style the middle?
GMT+8, 2025-12-24 22:29 , Processed in 0.089828 second(s), 18 queries .
