161 STL 6010 questions
发表于 2021-8-31 23:47:28 | 显示全部楼层 |阅读模式
I am useing my new TA 161 STL for some stick practice and I'm having problems with the arc stopping mid weld. I useing 1/8" 6010 @ 75-85 amps on 1/4" plate in the flat position and my ground is good. Is it the machine or me? When I'm running a bead I can adjust the acr length to control puddle size and it seems like everything is going along fine and then the acr just stops.Thanks for the help.
Reply:what's it do whith other electrodes?Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:I run a 161 STL from time to time mostly for field work. Gave you give any more info on the machine history? Does it happen right off the bat or an hour into welding? Any pics of the welds  your producing?  Since your still practicing, it might be a possiblty of user error. info info info
GMT+8, 2025-12-24 22:29 , Processed in 0.089763 second(s), 18 queries .
