Northern Tool Hybrid welder plug questions
发表于 2021-8-31 23:47:26 | 显示全部楼层 |阅读模式
I just bought a Northern Industries MIG/Stick 200 Hybrid welder. The welder came with a NEMA 6-50P plug. I'm trying to wire it to 3 wire 50A plug that will fit my generator. Can someone tell me how this plug is wired?I was thinking it had 2 HOT legs and a ground however inside the molded cord there is a black, white and green wire. Wouldn't that white wire be a nuetral?Confused. Could really use some helpJay
Reply:The horseshoe pole will be the ground while the 2 bladed poles will both be hot legs.  Che king on a meter the ground to each hot leg will be 120 volt but when both bladed poles are checked crossed you get 240.
GMT+8, 2025-12-24 22:09 , Processed in 0.154157 second(s), 18 queries .
