Weld pickers, hole finders, slag removers?
发表于 2021-8-31 23:47:25 | 显示全部楼层 |阅读模式
What do you use? Have you made anything unique that we should see?
Reply:I have a couple of chipping hammers i replaced the ends on them with threaded adapters and just screw in threaded hilti studs on the pointy end.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:slagfile Attached Images
Reply:As an inspector guys that hammer on their welds with a chipping hammer drive me crazy. I would recommend the slag file and or a slag shank just a sawzall blade with a hockey tape handle.Last edited by Letzgoracin301; 07-20-2012 at 09:18 AM.
Reply:I'd venture a guess that all that fancy stuff works REAL well inside a piece of 3" channel.Just sayin'"Any day above ground is a good day"http://www.farmersamm.com/
Reply:............ Looks like "weldbead" and I went to the same school.....The school of hard knocks. I think one of Murphy's Laws covers the breaking of a file.If everything seems to be going well, you have obviously overlooked something. Usually my file broke just as I was trying to finish up in the test booth...... Attached ImagesLincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
GMT+8, 2025-12-24 23:58 , Processed in 0.130010 second(s), 18 queries .
