slag- needle scaler and wire wheel?
发表于 2021-8-31 23:47:22 | 显示全部楼层 |阅读模式
Hey, I put my mig in the corner for a while and have been doin a bunch of stick welding- So whats easiest and fastest?   Should I just get another 4.5 in grinder and put a wire wheel on it and thats good to go or should I get a needle scaler too?   Thanks,  DaveMiller Synchro250 bought new 1997Millermatic200Miller Bluestar 2E . AC/DC 16hpBluestar 2E , DC Miller Thunderbolt225 AC/DC ArcLongevity 60 plasma
Reply:A wire wheel is a good way to go for cleaning slag.  A needle scaler or chisel will also remove slag but will mark up the surface of your weld.
Reply:I just use a chipping hammer, brush and scratch awl/pick.   If it's stubborn and I cant get it with those, then I break out the angle grinder with wire wheel.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I was just at the hardware store and the 4.5 in wire wheels they have, had a 1/2 in hole thats too small to fit on the grinder.  Will have to look elsewhere.Miller Synchro250 bought new 1997Millermatic200Miller Bluestar 2E . AC/DC 16hpBluestar 2E , DC Miller Thunderbolt225 AC/DC ArcLongevity 60 plasma
Reply:All I do is stick. I find an old fashioned chipping hammer and a wire brush so much easier than a wire wheel.Scott
Reply:Originally Posted by davo727I was just at the hardware store and the 4.5 in wire wheels they have, had a 1/2 in hole thats too small to fit on the grinder.  Will have to look elsewhere.
Reply:Originally Posted by scott brunsdonAll I do is stick. I find an old fashioned chipping hammer and a wire brush so much easier than a wire wheel.Scott
Reply:Speakin' of which..............How come folks beat on their wives?????Like to see them beat on someone their own size"Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-24 23:58 , Processed in 0.109970 second(s), 18 queries .
