removable trailer wheels
发表于 2021-8-31 23:47:12 | 显示全部楼层 |阅读模式
Gentleman,               Need some advice on trailer wheels just purchased a portable saw mill want to install trailer wheels on it. but would like to make the trailer wheels removable so when sawing do not have to worry about tripping over wheels. I am told that there are torsion axles out there that get pinned into square tubing pull the pins and take them off leaving axle in place . Any suggestions or ideas would be welcomed need 3500 lbs weight load.        Thanks Scott
Reply:http://www.dexteraxle.com/http://dexteraxle.com/i/u/1080235/f/...nformation.pdfMM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:you could make a frame out of angle iron that the springs attach to and then you bolt the complet unit to the saw mill frame Attached Images
GMT+8, 2025-12-25 00:24 , Processed in 0.097506 second(s), 18 queries .
