Name this part.... Its off a Miller 225G Plus
发表于 2021-8-31 23:47:07 | 显示全部楼层 |阅读模式
I assume this is some fuse but i dont see a reference to it in the parts manual. It appears to be a fuse of some sort but im not sure. Its sparking so I need to test/replace it.Thanks,Casehttps://picasaweb.google.com/1029544...35487235489650[IMG]https://picasaweb.google.com/102954403707682785914/Miller_Part#5768435487235489650[IMG]
Reply:Links don't workLincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Fixed the link - try it now.https://picasaweb.google.com/1029544...35487235489650
Reply:Have you tried looking in the engine owners manual parts list ? It looks like a voltage sensor.Mastering others is strength, mastering yourself is true power.
Reply:Appears to be a voltage regulator for the engine.Check out/join this group.  http://groups.yahoo.com/group/Onan_Engine_Club/You'll get an answer there. You will probably find the engine manual also.
Reply:Judging from the heat dissapating fins it looks like a solid-state voltage regulator, perhaps a zener diode.  How many wires does it have attached to it and to where do they go?- MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:3 spade connections?, can't really see. But on an old john deere engine ac in on the outer 2 and dc out on the center.
Reply:My vote is voltage regulator also. See this ebay post.John Deere 420 Onan P220 Voltage Regulator Rectifierhttp://www.ebay.com/itm/John-Deere-4...-/270798176650 Attached Images
Reply:It does have 3 wires. Many thanks
GMT+8, 2025-12-25 00:22 , Processed in 0.089082 second(s), 18 queries .
