Bad HF Wire?
发表于 2021-8-31 23:46:51 | 显示全部楼层 |阅读模式
Hay guys last weekend was in the middle of a project needed MIG steal wire LWS was closed so I bought a spool of wire from HF. Wire is Wire right if it says it is the same stuff..well no...copper coated looked fine...first thing it was not quite the right size..just a little tight, would feed but was hard to get started and yep cleaned the burr off the end. Ok welded a few hours, building a steal bed on a trailer so running long beads, any way the wire started to drag and jump. Hummm so I increased the pressure on the feed rollers then it jammed. well crap took off my helmet open the side of the machine and there was rusty dust all over the inside coming off the wire and it was wound very tight. Well changed wire to some .030 that I got from my LWS and it worked like a champ. Anyone else had a problem with HF wire? It was the stuff in the white box not the Hobart stuff.BrandonLincoln Tombstone 225 A/C Steel StickerOld Victor O2/Acetylene setupMiller Syncrowave 250 Tig/PC-300 PulserMiller Millermatic 212 Mig HTP Invertatig 201 Giant Teck D50 Plasma cutterLots of HF grinders
Reply:Waiting for callbacks. Ok remember, HF buys a lot of closeouts, overruns and discontinued items, and you don’t always know where it comes from. I’ve bought from HF with good luck. That’s the risk you take.
Reply:Moral of the story.Buy "mystery wire" and get "unknown results".Probably a cheap lesson when all is said and done.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:I usually just stick to McKay,  Lincoln, Hobart or Alcotec wires.   They're readily available, usually in stock in the type and size I need, consistently work good, and usually have a descent price.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I was at HF the other day, and some of their wire had rust-like spots all over it.Hobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:It's called old outdated stock.
Reply:yeah was a cheap lesson didn't break anything and ya gets what ya pay forLincoln Tombstone 225 A/C Steel StickerOld Victor O2/Acetylene setupMiller Syncrowave 250 Tig/PC-300 PulserMiller Millermatic 212 Mig HTP Invertatig 201 Giant Teck D50 Plasma cutterLots of HF grinders
Reply:I store my spools in Zip-Lock bags when not in use, if that helps.
GMT+8, 2025-12-25 02:08 , Processed in 0.129226 second(s), 18 queries .
