unsure if this is possible or not
发表于 2021-8-31 23:46:49 | 显示全部楼层 |阅读模式
Hey,   cruising craigslist and come across thishttp://asheville.craigslist.org/bfs/3166839005.htmlCan you really fill oxygen at home?
Reply:No you can't fill your tanks, but they do work great to use in conjunction with gas for a welding torch.
Reply:so It would run a small torch for welding?   would it run a cutting torch?     I do not know how much 3 liters a minutes is as compared to what a torch uses.
Reply:3lpm is 6.4cfhDoes that help.That oxygen concentrator only makes around 95% oxygen at best, so it's no good for cutting.  They are popular for glass workers using propane.  Makes the heating very inexpensive over the long run.There ARE oxygen concentrator systems that have a compressor to fill portable oxygen tanks, but they're very expensive, and I wouldn't expect to find one on CL.  It is also a dangerous operation.
Reply:Originally Posted by rlitman3lpm is 6.4cfhDoes that help.That oxygen concentrator only makes around 95% oxygen at best, ....
GMT+8, 2025-12-25 02:14 , Processed in 0.090603 second(s), 18 queries .
