bull guard ???
发表于 2021-8-31 23:46:38 | 显示全部楼层 |阅读模式
My son asked me if I could help him build a bull guard for his Toyota and my response was no because I had no idea what it was. So he goggled it and showed me. Than my answer was of course I can.So he and a buddy made a cardboard mock up and we went to work. First I changed the shape a small amount so that the material could be purchased in two widths and trimmed to fit (no bending all cut and welded)I tacked it together and let him and his buddy do the welding and grinding. After it was welded together he wanted to add holes for lights. (good luck) But the two of them were convinced they could do it and they actually did. With whole saws and the drill press (after I slowed it down for them) Attached Images
Reply:And done all with my 120 v wire feder Attached Images
Reply:Awesome bumper, that's exactly what I need to build for my Chev p/u."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Nicely done. And now for the back? MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:looks bad *** i need one  for my truck
Reply:That turned out nice.Millermatic 251Spectrum 300 PlasmaEverlast PowerTig 250EXEverlast PowerCool W300Harris / Victor OACraftsman 13 Speed Drill PressProTools Air/Hydraulic Bender48" BrakeCompressor, Notchers, Grinders, etc.
Reply:You welded on those tow points with the 110v wire feed?I dont care how much you beveled it, thats a bad idea and well outside the capabilities of the welder.  One of those is going to become a flying hammer.Have we all gone mad?
Reply:He wont need them anyway. Yotas don't get stuck. Millermatic 251Spectrum 300 PlasmaEverlast PowerTig 250EXEverlast PowerCool W300Harris / Victor OACraftsman 13 Speed Drill PressProTools Air/Hydraulic Bender48" BrakeCompressor, Notchers, Grinders, etc.
Reply:You welded on those tow points with the 110v wire feed?Cut holes welded front and back.and told the kids to use the tow hooks that came with the truck to tow out those Fords
Reply:Nice work. Made in the U.S.A.
Reply:That looks really good!  Some of the bumpers people make look way too bulgy and oversized but that fits the Yota real nice
Reply:I like the bumper.Nice build.What is the thickness of the material you started with?
Reply:Originally Posted by GillmisterI like the bumper.Nice build.What is the thickness of the material you started with?
Reply:Nice looking work... but...That big hole in the original bumper is there to allow lots of air to get to the A/C condenser and radiator.  New one is pretty, but no way do you have the same cooling capacity.  Don't try towing, don't visit the grand canyon in the summer, and really don't try towing in Phoenix in the summer. I used to design parts for heater & A/C systems for OEM in Dearborn MI...  We did a lot of testing in Phoenix, in the summer...You'd be surprised.  Front end airflow really matters.  Remember power steering and transmission fluid are affected too.  --zip.
Reply:Turned out awesome. Thanks for posting your pictures. I like these kind of projects... the ones that push the equipment and experience. I'm sure the kids learned a ton! Good job Dad.
GMT+8, 2025-12-25 00:24 , Processed in 0.089931 second(s), 18 queries .
