Using Pulser on AC Aluminum
发表于 2021-8-31 23:46:34 | 显示全部楼层 |阅读模式
Hay folks,Been playing with my Sync 250 with a PC-300 on Aluminum. Seems to be putting less amps in the metal but wow if you shorten the on time much it gets to be a mess unless you slow way down. Just playing, thought I would ask and see if anyone else was playing with it. Oh yeah running on 1/8 Alum, no filler, 120 amp max, green tungsten , 100% Argon and varying settings. Don't have much trouble with Alum, well for a goofball, without the pulser.  BTW Pulser setting I use on SS DCEN aren't even close, really didn't think they would be.....BrandonLincoln Tombstone 225 A/C Steel StickerOld Victor O2/Acetylene setupMiller Syncrowave 250 Tig/PC-300 PulserMiller Millermatic 212 Mig HTP Invertatig 201 Giant Teck D50 Plasma cutterLots of HF grinders
Reply:I have the same setup as you with the PC300 and I like it. I use a lot of amps and vary the on time. I also use the pedal, I just like it. I was playing around trying to weld beer cans end to end with 40 amps+ (Invertec) and got to the point that I could go a good way around. I have been using pulse lately on 1/4 inch at 250 amps 35% on and30% background and with preheat I can make a fair bead. I am just a hobby welder though.Good luckRobertSW250 with PC300Lincoln invertec V205t (on loan)Wilmington, NC
Reply:cool Robert....I have been messing with a few cast Alum wheels and find I can turn the amps up and very the on time to keep the heat down. It does take a bunch of messing with, to find the right combination.Lincoln Tombstone 225 A/C Steel StickerOld Victor O2/Acetylene setupMiller Syncrowave 250 Tig/PC-300 PulserMiller Millermatic 212 Mig HTP Invertatig 201 Giant Teck D50 Plasma cutterLots of HF grinders
Reply:There is a learning curve. I had mine for a long time before it started to make sense to me and now I like to use it. There are others that will tell you to put it away and forget about it though.I have a friend that has an older one and he would never put the current above what was required to weld at 100% on time so it never worked for him. He needed to have the on time near 100% to weld so what is the point of having it?? I try mine at 175 amps and pulse for 30% on time for 1/8 AL . Adjust the current or on time for adjustment. Just play with it and you will come up with your own process that will give good results for you.Have funRobertWilmington, NC
GMT+8, 2025-12-25 00:23 , Processed in 0.090932 second(s), 18 queries .
