Help. What is the name of this tool?
发表于 2021-8-31 23:46:27 | 显示全部楼层 |阅读模式
Thanks in advance.  I've been looking all over but can't find the name for the actual tool.  It is used to flare out the inside of the side wall of a tank in order to weld a ferrule or whatever to the other side.  I've seen them used but I never heard what they were called.  It leaves a smooth transition on the inside that looks like this: Attached Images
Reply:Like a dimple die?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:It's like that but i don't believe it is used with a press,  I was under the impression it was a smaller tool.  It was used to weld a 1 1/2" ferrule onto the side of a small tank. No way he got a press in there.
Reply:That rounded edge kinda leans me towards it was pressed. Tough one!  I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Hello Motorbreath, I don't know the exact name of it either. However, I believe that it is the same sort of tool that is used to "pull" tees on some pipe applications. It has a "finger" for lack of a better description that is inserted through an undersized hole. The finger is threaded and as the person using it unscrews it through a flange plate that sits on top of the hole it opens up the starter hole and "pulls" a sort of raised flange up and out to allow for the sort of connection that you are speaking of. Hope that makes some sense and maybe someone out there will have the actual name for it. I would like to know too. Good luck and best regards, Allanaevald
Reply:Flaring Punch or Flaring Die. Pretty common in the fuel tank world.
Reply:a dimple die with a bolt to press?Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:"T" Drillhttp://www.t-drill.com/tmp_t-drill-u...2&lang=9&s=224Lincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:It's a "Hootis"6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Sheet metal flare.  Some punch and flare, some only flare an existing hole.  Also known as a flange die or dimple die.http://www.tinmantech.com/html/punch_flare.php"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thanks guys. I was getting tired of running around in circles.  Anytime I did a search about a flaring tool, it always seemed to come back with something about copper tubing.
Reply:Flaring punch, I just bought one from snap-on and the tip broke off it, they make a punch with a sharp tip and further up the punch it widens to form a countersink, depending on your application these items can have a punch and die for iron workers.
Reply:It bugs me when I know of a tool or part I need and can't come up with a name to search.  For example, there are numerous different types of fasteners and washers but when you need an unusual one, good luck in describing it."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2025-12-25 00:23 , Processed in 0.105937 second(s), 18 queries .
