couple pics from work
发表于 2021-8-31 23:46:21 | 显示全部楼层 |阅读模式
not actualy sure what they are using this for, but its for kewit on the new portman bridge in the lowermainland bc.i didnt have much time to snap pics, but the weld closeup is one i did in the flat before the whole thing was assembled.oh and all the tacks in the first pic were to clean up someone elses horizontal that had to be ground down for a plate to sit flush on.
Reply:Your gas bottle shouldn't look soo ashamed. Last edited by brslk; 11-07-2010 at 01:51 AM.
Reply:you can  tell OSHA has  never visited your  shop.
Reply:I can't use MIG because I work outside, are the tarps to keep the drafts down so the shielding doesn't get blown away?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:i did not grasp the scale of that metal until the 3rd pic down with you / someone welding for reference!miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Originally Posted by retiredIWyou can  tell OSHA has  never visited your  shop.
Reply:I have nothing relevent to add, just thought it was cool to see that you're doing work for the company I work for- Kiewit.I rehab stuff, make stuff faster, and make stuff that never was.'99 VW Jetta TDI'73 Sears ST/12, '66 Sears Custom 6, Bar Stool Gokart
Reply:Originally Posted by jsm11Kewit is a big company....What are you looking @ that needs corrected?I don't know yet, I'm still green.
Reply:If I had to guess safety people would raise and eyebrow at:The blue tarps. - probably should be fire rated blankets insteadThe welding shield- holes/tears defeats the intended purposeThe boxes/lights on your oxy bottles- might want to see the bottle in a container or something... without a potential ignition source laying against the bottle.I rehab stuff, make stuff faster, and make stuff that never was.'99 VW Jetta TDI'73 Sears ST/12, '66 Sears Custom 6, Bar Stool Gokart
Reply:they arent oxy bottles,  its CO2.
GMT+8, 2025-12-25 00:24 , Processed in 0.092312 second(s), 18 queries .
