Paper Bucket
发表于 2021-8-31 23:46:20 | 显示全部楼层 |阅读模式
Had to make a tipping bucket hydraulically dump. Made some mounts and put a cylinder on it. The bucket holds paper bales and only needs to dump enough for it to slide out. I used a cylinder with a 14 inch throw. I still have to add lines and fit it to the forklift it will be going on. I use a Lincoln Ranger 10 with 1/8 inch 7018. All of my work is out of the back of my truck onsite. Its getting cold here in New England so I have to cherish the nice days like this.Cain's Mechanical LLC Southwick, MAwww.cainsmechanical.comRig:-2006 Chevy 2500 utility body-Lincoln Ranger 10-Miller Spectrum -Tons of hand and power toolsAWS D1.2 Structural Steel Certification
Reply:you permanently mounting it on the other lift truck?
Reply:Nice modification. Does the bucket have a stop on it? It looks like the cylinder rod could impact without a good stop.
Reply:The modification looks pretty good. Is that forklift going to take a 2K# cardboard bale bouncing on the end of the forks?
Reply:Originally Posted by forhireNice modification. Does the bucket have a stop on it? It looks like the cylinder rod could impact without a good stop.
Reply:Looks good, nice work.Probably needs a stop, if not for it's intended use then for when some guy takes it outside to clean the snow and ice."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:The forklift it will be going on is much larger than the one the one I was using to hold it up while I was working on it. The mount will be removable with quick disconnects on the hoses. They were using the bucket as a tripping bucket, but with 2k lbs that can get a little hairy. So now they use a flat plate and cut the bale apart and pull it off by hand. A stop sounds like a good idea because I know that something is going to give with out it. However, if it gets bent then I will have to fix it, another days work and pay, ahah. Thanks for the input and suggestions.Cain's Mechanical LLC Southwick, MAwww.cainsmechanical.comRig:-2006 Chevy 2500 utility body-Lincoln Ranger 10-Miller Spectrum -Tons of hand and power toolsAWS D1.2 Structural Steel Certification
GMT+8, 2025-12-25 03:54 , Processed in 0.071999 second(s), 18 queries .
