Cylinder size
发表于 2021-8-31 23:46:19 | 显示全部楼层 |阅读模式
I just got another cylinder for C25.  I didn't need it buy the price was so cheap it was almost free.Can anyone help me determine how many CF it is?It has 58.5" from the bottom to the top of the valve and has about a 10" diameter.  It is massive compared to my 80CF.It has Norland Smith stamped on it, never heard of them, and no search results on Yahoo.Last edited by jetlag; 07-02-2009 at 08:23 PM.Hobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:I meant Nordan Smith. haha, I guess that's why the search didn't show anything.Hobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:Nordan Smith is just another gas supplier like CapWeld, PraxAir, and others.  Here is a map:http://www.nordansmith.com/locationdelivery/You don't have one there in Memphis, so you might as well just GIVE me the tank!    I use the NS here in Jackson. I'm sure other suppliers will take the tank.  If they don't, perhaps I will buy it from you.It's not what you can buy, it's what you can build.
Reply:My guess is around 280 CF. Those dimentions are relatively close to those of my O2 bottles @ 282 CF.here's one link that shows some sizes.http://www.airgas.com/content/detail...=7000000000234
Reply:Originally Posted by JC'sWeldingNordan Smith is just another gas supplier like CapWeld, PraxAir, and others.  Here is a map:http://www.nordansmith.com/locationdelivery/You don't have one there in Memphis, so you might as well just GIVE me the tank!    I use the NS here in Jackson. I'm sure other suppliers will take the tank.  If they don't, perhaps I will buy it from you.
Reply:Originally Posted by jetlagFrom doing some searching, it may be 330CF????
Reply:Originally Posted by DSWIt's posible that it could be. the bigger tanks are usually taller or wider than that though.In all reality, since you will swap it, it won't make that much difference if it's 280 or 330cf. The size will show upon the paperwork with the new tank.
Reply:Originally Posted by jetlag 80CF is the largest tanks people can "own."
Reply:Originally Posted by JC'sWeldingIs this true?
Reply:Next time I am at Nordan Smith I will check on that.It's not what you can buy, it's what you can build.
Reply:Tomorrow I'm calling Nordan Smith, maybe they can tell me the status of the bottle if I give them the serial number.  Then it's off to NexAir or AirGas and see what they have to say about it.If they do exchange it, I think a tank this large filled with some gas might be worth a little something.  If not, I'll just keep it haha, and never run out of C25!Hobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:The issue of owner sized tanks has been covered recently.http://weldingweb.com/vbb/showthread.php...highlight=tank
Reply:Originally Posted by DSWThe issue of owner sized tanks has been covered recently.http://weldingweb.com/vbb/showthread.php...highlight=tank
Reply:I own 1 cylinder, but I have 5 cylinders I get filled. One acetelyene, 2 ox, 1 argon something and another . I "exchanged them at my local small welding shop for 282's,  330's , except for the acetyelene. I have no problem getting them filled for the last 20 years. I guess I'm glad I have a small local shop.  Bigger the better since the filling costs per volume is lower.
Reply:I own all my cylinders, sizes ranging from 40 to 280 in argon, argon/mix and oxygen, A to  I think C in acetylene.  Airgas fills and/or exchanges them all for me, no problem.   Some I bought new, some used.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:the actual volume of such a tank is less than 3 cf. i guess the rating of a tank ( the gas contained ) is a function of the pressure? a tank rated at 80 cf has 80cf of gas at atmospheric pressure squeezed into a tank of 3cf actual volume?the gas is compressed to less than 1/25th of its volume at atmospheric pressure?
Reply:Originally Posted by weldbead....i guess the rating of a tank ( the gas contained ) is a function of the pressure? a tank rated at 80 cf has 80cf of gas at atmospheric pressure squeezed into a tank of (XX)cf actual volume?
Reply:Well, I called Nordan Smith in Jackson and talked to a guy who was very helpful.  He said he can give me a 80CF C25 cylinder full if I returned the big boy 330CF to them.  But that is about a 200mile drive for me..hahHobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:oops, didn't mean to post.Hobart Handler 187Bainbridge bandsawMakita chop sawHarbor Freight 4.5" grinder
Reply:Bumping this thread...I am looking at two used C25 tanks for sale locally on CL.  One is 18" high and the other is 23" high.  Is there anyway to know estimate the cu/ft for these tanks?  I'm looking for a tank around 80 cu/ft.  Thanks
Reply:Originally Posted by StrokedWJBumping this thread...I am looking at two used C25 tanks for sale locally on CL.  One is 18" high and the other is 23" high.  Is there anyway to know estimate the cu/ft for these tanks?  I'm looking for a tank around 80 cu/ft.  Thanks
Reply:Looks like acording to the link I posted above, you're looking at  40cf and  60 cf tanks.Edit: looks like you posted while I was typing.
GMT+8, 2025-12-25 00:23 , Processed in 0.071517 second(s), 18 queries .
