I got gas...
发表于 2021-8-31 23:46:15 | 显示全部楼层 |阅读模式
and not the bad kind either.  I bought a nitrogen bottle today, picking it up after work.  can't wait to hook it up to my mig welder.  I used a friend's welder with gas and my welds looked a lot better, and it was akward using his welder because it wasn't mine.I can't wait!
Reply:Originally Posted by grphxand not the bad kind either.  I bought a nitrogen bottle today, picking it up after work.  can't wait to hook it up to my mig welder.  I used a friend's welder with gas and my welds looked a lot better, and it was akward using his welder because it wasn't mine.I can't wait!
Reply:Originally Posted by Broccoli1
Reply:Nitrogen is not used for mig to my knowledge. CO2, C25 (argon/ CO2) and a few other mixes for specialty use like spray transfer or SS, are typical.Broccoli1 was high lighting in bold letters Nitrogen and then the  showing he didn't understand the gas choice either.
Reply:Did you ever bother to ask your friend, what kind of gas? We’re all using laughing gas.
Reply:What kind of welding uses nitrogen?
Reply:Sometimes it is used with mixtures of He for laser welding, and at times as a shielding gas for Tig on certain alloys. It has some technical issues and is not commonly used in manual welding.
Reply:I'm pretty sure that is good for charging a barrel of Guinness.
Reply:Originally Posted by grphxWhat kind of welding uses nitrogen?
Reply:Originally Posted by makoman1860and at times as a shielding gas for Tig on certain alloys.
Reply:Uh bet he mis-spoke....bet he is picking up Argon/co or maybe Argon for Alum if Nitrogen I could use some in my car tires.......BrandonLincoln Tombstone 225 A/C Steel StickerOld Victor O2/Acetylene setupMiller Syncrowave 250 Tig/PC-300 PulserMiller Millermatic 212 Mig HTP Invertatig 201 Giant Teck D50 Plasma cutterLots of HF grinders
GMT+8, 2025-12-25 02:10 , Processed in 0.094697 second(s), 18 queries .
