Problem running 023 on millermatic 350
发表于 2021-8-31 23:46:14 | 显示全部楼层 |阅读模式
Hello,   I have a millermatic 350 with a roughneck 4012 gun and i am atempting to run .023 er70-6 wire (30 lb roll) to weld 18ga sheet metal I have a new 023 liner, rolls ,inlet ,contact tip and 75/25 argon co . I have spent hours trying to get this setup to run properly. I got a ok bead or two once the metal is warmed up but nothing consistent  also the wire will break at the guide often. I have adjusted volt and wire speed setting tightened/loosened rolls for hours I even contacted miller and got there recommended settings. I don't know what I am missing or doing wrong the machine runs fine with my 045 setup for the thicker stuff. Any thoughts or advice? Thanks Jason
GMT+8, 2025-12-25 02:09 , Processed in 0.091649 second(s), 18 queries .
