downhand 5p+ 6010 (pipeline) cwb test?
发表于 2021-8-31 23:46:13 | 显示全部楼层 |阅读模式
im just curious to know what the general downhand 6010 5p+ cwb test is, im sure there different procedures for different size pipes when being tested by a company but just wondering what the general test isany information is appreciated,,,ty in advance
Reply:Usually, not always, but usually, the test you have to burn is a 12" butt-joint in the 5G or 6G position, beveled edges end to end, and then the other is a 12" 90 degree branch.  The branch is the real S.O.B.  You have to  cut the fishmouth, bevel, and fit the two pieces... it takes the better part of a day and they may or may not allow you to use a template.
GMT+8, 2025-12-25 00:23 , Processed in 0.120156 second(s), 18 queries .
