Pro Core 100
发表于 2021-8-31 23:46:11 | 显示全部楼层 |阅读模式
Does anyone have the specs on a Lincoln Electric Pro-Core 100?  I believe it has been discontinued and I cannot find the specs anywhere on the web.  I have this welder and it has only been used less than a half dozen times and simply cannot find the book that came with it. I've heard the Pro-Core 125 K2579-1 is the current equivalent.  Any additional info you can provide would be greatly appreciated.
Reply:http://www.lincolnelectric.com/asset...oln3/im562.pdfLast edited by Broccoli1; 08-06-2012 at 05:22 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-25 05:44 , Processed in 0.104358 second(s), 18 queries .
