Jig question
发表于 2021-8-31 23:46:09 | 显示全部楼层 |阅读模式
I want to join two 12.7mm carbon steel tubes at a right angle.I have precut a 45 degree angle on both.My question is, if I'm using a wooden work bench which is covered cmopletely with a 5mm sheet of steel, what's the best way to hold these tubes together while I tig/mig/stick them together?I don't mind making a jig and attaching it to the table somehow.Thanks
Reply:Originally Posted by HanzelzI want to join two 12.7mm carbon steel tubes at a right angle.I have precut a 45 degree angle on both.My question is, if I'm using a wooden work bench which is covered cmopletely with a 5mm sheet of steel, what's the best way to hold these tubes together while I tig/mig/stick them together?I don't mind making a jig and attaching it to the table somehow.Thanks
Reply:^ worked a treat!Thanks
GMT+8, 2025-12-25 00:24 , Processed in 0.069446 second(s), 18 queries .
